02 ws6 vs 98 formula suspension
1 Post
honestly, probably just from the car being older. even an 02ws6 is 8 years old, and the suspension is going to be worn even if its low mileage.
my 01 firehawk has basically the same suspension as a WS6, and with only 47k miles on teh car, which is garaged, the stock front control arm and sway bar end link bushings are all cracked. As stuff wears out, i replace it with upgraded aftermarket parts... even the WS6 suspension pieces, like the PHB and LCAs, they are just stamped steel and you can twist them by hand.
