speed bleeders
Old 01-21-2010, 09:22 AM
goof4080's Avatar
Default speed bleeders
anybody know what size the bleeders on my 98 T/A are?
I'm looking to facilitate my one man garage operation
and in case u don't know what i'm talking about.....these:
Old 01-21-2010, 09:48 AM
Nightrydass's Avatar
The ones i bought sucked ***. The front bleeders wouldn't tighten down on the caliper. Fist i thought i used the rears for the front, so i swapped them and STILL had an issue. FWIW, i would stay away and buy one of those one person pump bleeders.
Old 01-21-2010, 02:10 PM
goof4080's Avatar
ok, well your bad experience did not answer my original post. And you shouldn't be leaving the speed bleeders on your car for everyday use. I've used plenty on many different vehicles. Anyone else want to actually answer my question?
Old 01-21-2010, 02:40 PM
Well chief, my point was that b/c i couldn't fully tighten them, i couldn't properly bleed them. IDK if i got a bad batch or what, but they sucked. That is why i suggested using the solo pump bleeder. I'm just tyring to save u a headache...
N e way, i bought them from a sponser here, Texas Speed. Look under F-Body brakes and they have everything you need. Direct link to the page with them is below.
http://www.texas-speed.com/shop/cate...MID=1&catid=34
Old 01-21-2010, 02:52 PM
white2001formula's Avatar
I don't know what size they are, but I do know that the front and rear are different. Maybe not by thread size, but they were different when I replaced mine with Earl's solo's.
I don't see how it would be bad if you kep them on for daily use. What's the point of solo-bleeders then? When you tighten them up, it cuts off the ability for fluid to be released.
Old 01-23-2010, 09:03 AM
fast377's Avatar
Pretty sure they are 10mm. And if I remember correctly, the ARE the same front and rear. From my experience...they are GREAT!!
Quick Reply: speed bleeders
