Spohn crossmember mounted torque arm and Texas Speed True Duals
Old 01-24-2010, 01:19 PM
Wingman WS6's Avatar
Default Spohn crossmember mounted torque arm and Texas Speed True Duals
I was looking at a used set of Texas Speed True Duals and was wondering if it would fit around my Spohn crossmember mounted torque arm.
I know on Texas Speeds web site it says not recomended for body mounted torque arms.
Anyone with this set up or is this a deffinate no go?
Thanks!
Old 01-24-2010, 04:46 PM
UMI Performance's Avatar
Hello,
Unfortunately the TSP system will not work with the Spohn tunnel mounted torque arm. The X is right where the torque arm mounts to the tunnel area.
If you look at the link below there are installation pictures of the TSP system and a torque arm we offer. This might help you some-
www.umiperformance.com/2205
Hope that helps,
Ryan
Old 01-24-2010, 05:24 PM
That's kinda what I thought. The pictures are worth a thousand words! Thanks!
Old 01-24-2010, 05:34 PM
Glad to help! If you want to change your torque arm out let me know
Quick Reply: Spohn crossmember mounted torque arm and Texas Speed True Duals
