torque arm?
Hello
Like mentioned above as long as you plan on keeping the vehicle at stock ride height you will be fine. We manufacture ours with -2 degrees pinion angle into it. If you plan on lowering the vehicle I would highly suggest going with a adjustable torque arm. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...j452ms1di4if66
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
No Problem! That's what I am here for. In that case it might be off slightly but I am sure it's not even noticeable. If you aren't getting any vibrations you should be good! If you are I would suggest looking into a adjustable torque arm.
Thanks
Brad
Thanks
Brad
