Which Shocks/Struts for a 1.25" drop?
Yeah, Koni's are great, plus you can use a lower perch in front/heater hose in back to drop your car around 1 inch without affecting drive quality much at all. Otherwise, Strano makes great springs for fbody's.
You can also go SLP Bilsteins and Strano springs for less money, and it should still be a big improvement over stock.
Koni sa shocks is the ticket.The lower perch on the fronts will give you 3/4" and the hose mod in the rear will drop it app. 1/2 ".If that's not enough get the Strano lowering springs .
They are the best.Call Strano performance.
