Could this just be my springs or suspension?
Here lately, I've noticed that my car leans to the right a little when I look at it from behind. Also, when driving, i hear a squeek coming from the rear right. It almost sounds like when a grocery cart's wheel is messed up, and makes a squeeking sound.
I went to a body shop, and they were going to try and charge me $1000+ because they said without even putting it on a lift, it had to do with a strut tower or something. I call bs on that. So could it possibly just be my suspention? I believe the springs and suspension are all stock, and it's a '99.
tons of 4th gens are slightly lower on the passenger side. if you search you'll find hundreds of posts about it. nothing to be concerned about. chances are the squeak is entirely unrelated.
Just another Idea check your LCA bushings and Sway Bar bushings as well. If your LCA's are grease able I would suggest giving the 1 1/2s pumps of grease. Hope that helps!
Take it easy
Brad
Take it easy
Brad
