Bent Front Spindle?
Old 02-14-2010, 03:55 PM
97pontta's Avatar
Default Bent Front Spindle?
I'm working on swapping my 97 over to LS1 brakes front and rear. I picked up all the used parts and started to get the front LS1 spindles ready for powder coating today when I noticed one of them looked different. I measured them in a few different manners with the same results. I would imagine many of these used spindles are bent but how much can be adjusted for when doing an alignment? There is a difference of 7/16 - 1/2 inch between the left and right spindle. I don't know which one is the good one, just that they are different.
Below are pics of the spindles with a straight aluminum bar clamped between the spindle wheel bearing mounting surface to measure from.
Right Spindle
Left Spindle
Measurement setup
Old 02-14-2010, 04:31 PM
99Bluz28's Avatar
The height between the upper and lower ball joints should be the same as on your 97 spindles, use them for reference measurements.
Old 02-14-2010, 04:43 PM
97pontta's Avatar
I though about that also, but they are still on the car. I was hoping to get all the LS1 parts ready before I removed the LT1 stuff so I could move the car if needed.
Old 02-14-2010, 06:15 PM
mitchntx's Avatar
I've measured them similarly, just laying them flat on the shop floor, side by side. A difference is grossly obvious.
Old 02-14-2010, 08:39 PM
rednari's Avatar
Ask Sam Strano. He probably knows and is usually helpful in these matters.
Quick Reply: Bent Front Spindle?
