QA1 springs
Old 02-18-2010, 01:28 PM
slick red z's Avatar
Default QA1 springs
Going to get new qal's for the front, just wandering what qal springs to get. I still daily drive my car but I still go to the the track alot. They are the f series single adjustable coil overs.
Old 02-18-2010, 01:31 PM
rtr2001ss's Avatar
I'm running the 300lbs spring on mine.
Old 02-18-2010, 01:50 PM
UMI Sales's Avatar
Hello
Like mentioned above. The best street/Strip set up is the 300 lb springs for sure. Below is a link to show you what all UMI Performance has to offer.
http://www.umiperformance.com/catalo...Path=7_110_159
What front coil-over do you have? If by chance it is the R Series they are only valved for a 275lb spring. If its the F Series then you will be fine!
If you have any other questions feel free to ask!
Thanks
Brad
Old 02-18-2010, 03:12 PM
airforcemanss's Avatar
i want to get these shocks eventually but what is the point of going with a 300lb spring with the stockers do just fine rated at 296?
Old 02-18-2010, 03:40 PM
BMR Tech's Avatar
The only way you can run a stocker spring on the QA1 setup is to use one of our spring cups.
The listing for the cups can be found HERE
Another option to the QA1's are the Strange units. We have used them in for a variety of different applications and prefer them over the Qa1 shocks.
The listing for the shocks can be found HERE
Old 02-18-2010, 05:36 PM
thanks guys you answered my questions
Old 02-18-2010, 11:53 PM
mr_biscuitz's Avatar
I dont daily drive my car but I drive it a lot on the weekends and nights during the summer. I run the r series coil-over set-up up front with the 275 spring and never had any issues. I also run skinnies up front if that matters. The rears are the f series with stock springs cut down.
Quick Reply: QA1 springs
