Should I change my springs?
i have a eibach pro kit and i have heard that the springs suck mostly because the back is too soft...should i buy BMR rear springs only and keep the eibach fronts? would that make a big difference? i have bilstein shocks.
patience my friend, it's only been a few hours. is it the lt1 or ls1 pro kit?
are you willing to let the ride get a little stiffer (although lessen frequency of hitting bump stops) and possibly lose some launching capability?
The problem people usually have with the pro-kit is from the rear spring rates being to soft for the ride height, and them eventually sagging. The LT1 pro-kit is the better of the two (better spring rates). IMO If you've already got them, mount them(since nobody will probably want to buy them) , then when your 100% sure if you like them or not you can make a well informed decision.
ok well im putting bilstein shocks in anyway and im going to start to autox but dont have the money for stranos and koni so originally i was gonna go bilsteins and prokit and i was just wondering if i should go bilsteins ls1 prokit up front and bmr springs in the back?? and if that would make a diference in handling?
