Steering shaft bolt?
Old 02-26-2010, 08:17 AM
bigwill12187's Avatar
Default Steering shaft bolt?
Hey everyone, does anyone know where i can get the bolt that goes to the steering shaft. I think I lost it and cant find it in my shop. Any help would be great thanks. Here is a picture of what im looking for I set it as an attachment. Thanks again.
Old 02-27-2010, 08:14 AM
Anyone know?
Old 02-27-2010, 11:06 AM
tillery's Avatar
Autozone carries metric bolts that may work there. I think it may be a 8mm bolt. If not use a smaller diameter bolt and nut that will pass thru threads to tighten down till you get correct one. Dealerships rarely keep benchstock on hardware and charge too much. Unless a local salvage yard will let you get one out of a GM vehicle. A truck should have same bolt too.
Old 02-27-2010, 12:10 PM
mitchntx's Avatar
It does appear to be an 8mm bolt and a 1.5 thread pitch.
http://lawmotorsports.net/Pics/SteeringBolt.jpg
But notice the elongated shoulder. That locks the shaft to the spline. Use a standard bolt in an emergency. But get the right fastner for the job.
Quick Reply: Steering shaft bolt?
