Raising rear of lowered car
Old 03-01-2010, 02:02 AM
NoGamesLS1's Avatar
Default Raising rear of lowered car
I have a firebird with an eibach pro kit. I want to raise the rear of the car just a little bit. About 1/2". I do not want to put the stock springs back in. Can a firmer shock help do this?
Old 03-01-2010, 02:21 AM
99Bluz28's Avatar
No, the rear shock has nothing to do with the rear ride height.
You could put some rear Hotchkis 1" lowering spring in it.
Old 03-01-2010, 02:27 AM
StrokerAce03's Avatar
^^^What he said. Did you take out the isolators when you put in the rear springs? That'll give you 3/4" right there.
Old 03-01-2010, 02:45 AM
NoGamesLS1's Avatar
I'll have to look. The kit was on when I bought the car. You are talking about that rubber piece right?
Old 03-01-2010, 03:02 AM
nauticalstar2012's Avatar
If the isolators are gone you could always try and slide some thick heater hose over the first coil and see if it helps a little...
xXxSilveradoxXx's Avatar
Yeah, the little round rubber piece above the rear springs.
Old 03-01-2010, 03:06 AM
NoGamesLS1's Avatar
Thank you guys I check it out tomorrow
Old 03-01-2010, 03:07 AM
Searching4Sierra's Avatar
yes the rubber "cup" on the top of each rear spring
Old 03-01-2010, 11:42 AM
MosesMcgregor's Avatar
you may want to check to see if the isolators are in there. If not, they would help
Old 03-01-2010, 12:16 PM
EchoMirage's Avatar
if theyre gone, im sure you can get some used isolators off this board. lots of people remove and toss them.
Old 03-01-2010, 01:27 PM
FirstYrLS1Z's Avatar
available at local part stores
http://catalog.makewavesinstrumentco.../catalog20.htm
#18900
When I took off the OEM shocks(which are 'gas charged' and do 'lift' slightly) and went to QA1 double adjustables(not gas charged) I used those as a quick and dirty fix to get the height back to OEM. One package of 4 is all required,2 per coil spring. No dis-assembly of spring required for installation.
Quick Reply: Raising rear of lowered car
