C5 brakes on my WS6-quick question
I cant find this anywhere, so just have to ask a simple question.
Since the rotors for the Vette brakes are bigger than my stock FBody ones itll pull the caliper farther away which means I need to get longer brake lines from a corvette right? I have steelbraided lines on my stock brakes now, and just wanted to make sure I need to get vette brake lines to do this upgrade. Thanks
i went through the same thing when i did my C5 swap. LS1 lines will work, but personally id feel more comfortable with lines just an inch longer. if you can get lines made that are just a bit longer, itd be best.
i did my swap with BMR convertor
its nice , but dont forget you should use 17" wheels
i did it and now i'm going to install B/S street lite wheels but the daeler told me you cant
with c5 brake
with c5 brake
clearance & spacing
