? About C5 conversion brackets.
Ok so i know that the late LG brackets you could still use your stock F-body Caliper and use a larger rotor. is this possible with the UMI or BMR Brackets? Im trying to see if for now i can buy some Z51 Rotors and use my stock Calipers until i get some Z06 Calipers. Anyone know?
So basically if you wanna do the Z51 brakes all you have to do is add rotors to the kit? Or does it require a larger bracket to place the caliper even farther away to clear the larger rotor?
i have your brackets and i have to say, it appears that the kit will work with a larger Z51 rotor IF we use the f-body abutment brackets. The C5 bracket is actually smaller than the f-body one and brings the caliper to the correct location for C5 rotors, but have you guys tried with the Z51 rotor? It may be a swap i'd be interested in if i decided to get some 18s.
Can you om me when you get this done? thanks.
