HELP!!!!!! Rear brake issue!!!!
Old 03-13-2010, 06:27 PM
thegroup's Avatar
Unhappy HELP!!!!!! Rear brake issue!!!!
heres the deal. 2000 Z-28 step up for DRAG Racing only. got a set of pacer 15'' drag wheels for the car ( narrow front wide back) on the front had to grind a little off the caliper, no prob. now on to the back. when to put the backs on (hadnt had a chance to bc i was geting the rear end rebuilt and just got it back on the car today) found out the wheel hit the caliper and dont think i can grind enought to make it work. if anyone knows, will rotors and calipers from a 93 to 96 (or earlier) camaro be small enough to work or is there a company that makes a kit? i have caliper brakets from a 93 z28 so thats why im asking. also getting rid of the e-brake system WONT bother me a bit. really have no use since the car is an AUTO. ive seen 15s on newer camaros before so any info will be a great help.
Old 03-13-2010, 10:58 PM
getusumws6's Avatar
not sure about the pacers but when you put a 15" race wheel on( unless its a Bogart) you most likely will have to do some grinding to make them fit. or you can do what most do and use a spacer.
Quick Reply: HELP!!!!!! Rear brake issue!!!!
