need help cts-v conversion
Old 03-17-2010, 01:26 PM
kail's Avatar
Default need help cts-v conversion
Hey, got the 2006 cts-v calipers and im going through the install.
Need some help figuring out which size wheel spacer i need. I have 18x8.5 ruff racing 278 with 35 mm offset in the front. Anyone know off hand? or could give me an approximate?
any help would be appreciated, thank you.
also, if someone knows the lengths of the steel braided line ill need, it would make things easier.
Old 03-18-2010, 06:59 AM
No Juice's Avatar
You will need the Eibach-Pro 15mm(1/2") spacer, Part Number 90.6.15.003 The spacers come with new longer studs as well.
You will need the steel braided lines from Flynbye Performance or flynbye.com
You may want to check out this thread first.
https://ls1tech.com/forums/suspensio...ake-lines.html
All the information is in this thread
https://ls1tech.com/forums/suspensio...ll-w-pics.html
Old 03-18-2010, 12:00 PM
kail's Avatar
thank you, i wasnt sure if 15mm would do it or i needed slightly more. As for the steel braided lines i saw the issue with back orders, anywhere else to get them?
