Stock height: LCAs pointing up going towards axle?
Old 03-17-2010, 09:26 PM
slp_z28's Avatar
Default Stock height: LCAs pointing up going towards axle?
I thought these were supposed to run parallel to the ground?
Old 03-17-2010, 09:37 PM
NVR_SPDS's Avatar
the best position from what i understand, is parallel to the ground. Stock may not neccesarily be right. Just throw on some relocation brackets and set em where they should be.
Old 03-17-2010, 09:44 PM
slp_z28's Avatar
I have a set that I pulled from my previous 10 bolt that were welded on. They're a little bent up. I think I can bend them close though. Should work, right?
Old 03-18-2010, 07:13 AM
UMI Sales's Avatar
Hello
If the vehicle is lowered or even has the heater hose mod done to it. It will angle the LCA at the incorrect angle. Like mentioned above to allow you adjust the LCA to the correct position a set of Relocation Brackets will be the solution. Below is a link to show you what all UMI Performance has to offer.
http://www.umiperformance.com/catalo...39o5hov32gp3s2
If you have any other questions feel free to ask.
Thanks
Brad
Old 03-18-2010, 08:57 AM
slp_z28's Avatar
I see, but I already have some relo brackets, UMI. I guess it would be wise to install them then.
Old 03-18-2010, 11:22 AM
98TAjwh's Avatar
depending on how bad they're bent up, i'd recommend a new set. bending them back can weaken the metal.
