Sfc ?
Sfc ?
i installed SFC's that are welded on one side and bolted on the other.
since then, if i hit a sharp bump just right it sounds and feels like the sfc is slamming against the underside of the car.... is this possible? would welding the other side of the sfc's solve this?
any other ideas of what this could be?
Hello
Its possible that the hardware could of worked loose. I would suggest look to see if you can see where the clearance issue is. And make sure the hardware is tight. And then if you would like just weld it like the opposite side.
If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
