SS Brake Line Install Help.
Just looking for some info on the install. I purchased a set of RPMSpeed Stainless Steel Teflon Brake Lines Front and Rear.. WITH Traction Control from WS6store and there weren't any directions. Is there anything to be carefull with while disassembing? Where does the line for the Traction Control go? Searched for a write up but found nothing.
Thanks for the help.
A traction control kit should have 6 lines total. One for each corner of the car and two lines at the diff.
Buy some cheap brake fluid and make sure you keep the MC full. Keep topping it off with the cheap stuff. Then flush it out when you are complete with the line R&R.
