2002 TA WS6 Z06 Brake Kit upgrade Rear?
So I am going to do the Z06 brake kit upgrade on my front brakes and I figure why not do the same for the back to keep it all uniform even if there isnt really that much of a change. My question is this, I am going to change out the rear end soon and put a Strange S60 in, Before so Obviously I wanna do the brakes but I`m curious what will need to be done to the mounting area in the rear to put the Z06 brakes? Will the stock backing plates still stay the same? Anyone ever done this?
I talked with the company as well, if you have TCS and e-brake, you can only run one of them with the $600-700 bracket. If you go with the cheaper one, you have to delete both.
The rear upgrade would be strictly cosmetic as well as making everything uniform on the car once the front is done.
My understand is the rear can accept a C5 z06 rear caliper with no mods as long as the stock Rotor is used. That being said I would assume i would have to then use a c5 z06 pad?
