whats the difference in kmembers
im getting ready to do my swap and i wanted to know what the difference is!
when it comes down to say for exampe what is the difference between a
BMR Standard LS1 Tubular K-Member (Pinto Rack) and a BMR Race Tubular K-Member (Motor Plate/Pinto Manual Rack) AND a BMR Race Tubular K-Member (Motor Plate/Factory Rack)
Lets see if this helps-
BMR Standard LS1 tubular K-member (pinto rack)
Anything else just let me know
- This K-member will allow you to bolt your LS1 motor right in using the factory motor mount portions that bolt to the sides of the block.
- Cannot use factory power steering rack only after market pinto manual rack.
- This has no provision for the factory motor mount and requires an aluminum plate across the front of the motor to mount in car.
- CAN use the factory style power rack an pinion
