Rear Spring Install
Rear Spring Install
Hey guys, I have Strano springs I need to get installed on the rear (fronts get installed Tuesday or Wednesday). I don't have the rear shocks yet since they are on back order, but I'd like to get the rear springs installed.
My question for you all is...to remove the stock rear springs do you have to unbolt the shock, or can you remove the spring without unbolting the shock?
Any help is appreciated.
So, I could just unbolt the bottom of the shock and that would work?
Yup, unbolt the bottom of the shock and lower the rear. The spring will basically drop out. Just make sure when you lower the rear that nothing binds up or gets caught on anything.
