Where exactly are my abs sensors located?
Old 04-20-2010, 03:52 PM
Blue_GTO1199's Avatar
Default Where exactly are my abs sensors located?
I have a 1999 Trans Am, and my abs inop light started coming on. I was told to check my sensors to make sure they aren't too dirty. I know they're on my wheels, but where EXACTLY? Also, what do they look like? Are there any other abs sensors other than the ones on the wheels?
Old 04-20-2010, 09:44 PM
Randy WS6's Avatar
There on the back side of your backing plate ( dust cover) If you have the four channel ABS , They are a round black sensor with a two wire plug on the sensor,and you will need to remove the bolt ,use a 10mm wrench .When you pull it out it will have a round prong sticking out of it, it a magnet, clean it off with a rag
If its a three channel ABS the sensor will be on the rearend housing .
Old 04-20-2010, 11:25 PM
offroadfury6's Avatar
do u need to take the tire off if its a 4-channel? or can u access it by just crawling under?
Old 04-21-2010, 06:40 AM
Randy WS6's Avatar
You can take them off with the tires on , but it is tight.
Old 04-21-2010, 07:42 PM
ok, so take the tire/rims off lol...gotcha
Quick Reply: Where exactly are my abs sensors located?
