how do i adjust spohn sway bar?
installed the drag spohn sway bar and im not sure how to go about adjusting it? i 60'd 1.61 before the drag bar and i installed it but also went to a SD tune and pulled a 1.57... im sure there is a little more left in it but i dont know which way to go on adjusting it. i also dont have sub frame connectors, anybody had luck with subframe connectors?
Hello
I would say you really need to get a set of SFC's ASAP. To not only help with weight transfer but also help keep the body from getting damaged such as dimples in the quarters. And once the vehicle is solid due to the SFC's then I would worry about adjusting the drag bar because until then. The chassis is going to flex anyway it wants. And there is no controlling that until you install the SFC's. If you have any other questions feel free to ask. And I will be more than glad to help. Below is a link to show you what all UMI Performance has to offer as far as SFC's
http://www.umiperformance.com/catalo...oj76e1csojj822
Thanks
Brad
Thanks
Brad
If you like give me a call here at the office and I can tell you how it needs to be setup
