Clunking sound in front passenger wheel well
I have been trying to troubleshoot a very annoying clunking/rattling sound coming from my front right wheel somewhere. It seems to be at the worst when I'm driving slow in my neighborhood or in parking lots on uneven roads. I put it on ramps and got under it and inspected everything the best I could, pushed and pulled on my tie-rod ends, steering rack, shocks everything looks and feels solid.
With the car jacked up I tried grabbing the wheel and getting it to move up and down or side to side, but it's solid as well. I can't see any obvious worn bushings . What the hell is causing this sound. I'm thinking about just taking it to a shop, will they charge me for looking at it and letting me know if anything needs to be replaced and what's causing this? Anyone ever had this problem? Thanks.
I thought it might be the wheel bearing, but the other day, i took off the wheel and removed the calipers and rotors and the bearing spins just fine and there is no play.
The usual cause for this is bad bushings (control arm, sway bar end link, shock). It can also be a bad ball joint if they get really bad.
Yes, the shop will probably charge you. Time = money.
Your upper shock mount nut is likely loose.
Jack the passengerside front up until the wheel is at full droop, remove the wheel and place a jack-stand under car. Now now place your Jack under the lower control arm ball-joint, now carefully look for a gap, or lack of between the bottom of the upper mount and the very top of the shock dust boot assembly start slowly raising the lower control arm with the jack while looking is the above area. If the gap changes noticeably then you upper shock mount nut is likely loose. For a better reference do the same to the driverside first, then the passengerside.
Use a pry bar. Think about how much weight your suspension supports. You said you grabbed a bunch of components and I would assume wiggled them. That will only work if your parts have worn down to the absolute worst case.
for some reason that shock nut rusts out bad,, water sits right in there. I took mine off a few weeks ago and the nut was compleatly eatn away,, had to cut the shock off and replace them.
But I would bet your end link on your sway bar is broke or loose on one side. Also check your lugs,, sounds stupid but better safe then sorry.
Well, I took my shock out over the weekend, the rust wasnt bad at all, but the nut that sits on top was stripped inside and just slid up and down on the threads, also I could easily push and pull the piston in and out of the shock, I guess its time for new shocks.
