road feel 2000 t/a vert
should also mention it a ws6, I know these cars have sport suspensions but is there any way to eliminate the hard feel when you hit railroad crossings and expansion cracks on the road? car has low mileage, sfc's, strut brace, how low can I go with tire pressure?
You can buy a Calvalier, I hear they ride nice.
Without compromising handling there is nothing you can do. Lowering tire pressure will do nothing but accellerate tire wear. I run mine at 32 psi and would run no lower than what ever is on the door sticker (27 psi I think).
Re'
Re'
Hello
Like mentioned above! If you are looking for a better ride quality then look into a set of shocks. But keep in mind you are dealing with a vehicle that is 10 years old and it is possible that the bushings in the control arms are shot as well. And I would suggest doing a inspection and see what type of shape they are in and the hardware as well. If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
thanks for the replies, I fully realize there's a compromise for handling vs ride and maybe I'll try some new shocks, the car is pretty tight and only has 35000 miles, just thought someone might have figured this out.
Expansion cracks never feel good. Especially with P275/40ZR17 tires.
There are no shocks that will make these cars ride smooth on a rough surface. The best you'll get is a well controlled ride, which the Bilsteins provide.
Part #'s:
Front: F4-BE5-2406-M2
Rear: F4-BE5-2407-H0
BTW, I kept the stock springs. They are your best bet if you are looking for ride quality.
Part #'s:
LS1TECH Sponsor
Yep, shocks will help a ton... that's the major issue.
I'd say a set of SLP Bilstein's (being that they are just cheaper than Bilstein HD's to your door)... $409.99 shipped for a set if you live in the continental US would be a good choice.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Keep in mind the tires you have also play a noticeable part in your cars ride quality. I don't know what tires you have on your car, but if you have the cheapest tires available, there's usually a good reason for that, it called compromise. Good shocks, and quality tires with the correct air pressure (30-32psi) will go a long way in keeping the ride quality very livable.
they are firestone firehawks 275/40r17, will admit I like a cushy ride better, when you can't feel the road, still love the car but if I can improve on it to suit me I'll give it a try, any suggestions on a better tire that will work?
