need some help removing rear rotors?
I started my rotor swap today, finished installing the front rotors/pads and painted the calipers and bracket. Now i just started on the rears and im having trouble, so i need some help guys.
Ive taken the caliper and even the bracket off. Ive removed those little washer type things infront of the rotors that help keep the rotor in place. Now i just cant get the rotor to come off, is there something im missing?? A certain way im supposed to take these or what? im lost lol
if you don't want to have to deal with this again next time, put a little anti-sieze on the hub (not so much that it gets slung off at high speeds, tho, just enough to coat the hub surface)......this will help keep it from rusting together and it should be easy to remove the rotors next time without having to break out the hammer.
