Is there any cheap brake conversion kits?
I built up my motor and now stopping is a issue all the kits I see are about $700 or more and that only is for the front or back is there a good kit to use that I can use for the front and the back for about $700? I would really like any help you can give. Thank you for your time
You wont see too many kits for the rear because too much stopping power on the rear brakes will cause wheel hop. You will even see racers (auto-x /road race) use a less aggressive pad in the rear than the front.
Many go with a C5 kit in the front and use good pads/rotors in the rear. Without getting too pricey I don't see why some good hawk pads and decent rotors wouldn't work for you.
http://www.stranoparts.com/partdetai...D=17&ModelID=7
Just don't waste your money on drilled rotors...
Brakes link
Try this link, I do believe they sponsor LS1Tech but, I can't find them so I hope this is okay. It's around your price range but, look in the brake section and shop around.
http://www.hawksthirdgenparts.com/br...ersionkit.aspx
Steve
Steve
I did the C5 front brake conversion with a kit I got from WS6 Store, a sponsor here.
http://www.ws6project.com/user_stor/...oducts_id=2028
I consider it to be one of the best modifications I've done to the car. Very happy. I had problems before with warped rotors on the stock set up. The Corvette ones can be stopped hard without worry about warping.
You do have to cut your stock spindles. I used a Sawzall with a metal blade and it was simple.
