suspension rattle...is this normal?
hey all, ive got an adj phb, relocation brackets, adj lca's, edlbrock trq arm, stock shocks and springs. I noticed that when i go over rough pavement like cobblestones, or the like, eventhough they'll have a smooth surface, the rear suspension will rattle as if there's something loose, and i had it all installed a few weeks ago. What could be rattling?
Looks guys, your replacing stock, cheap, flimsy stamped steel suspension pieces and soft rubber bushings with polyeurethane, solid rod ends, and chromoly or tubular steel pieces.
The **** is going to rattle, no matter what. The stock stuff was made to be cheap and soft, you replaced it with hardcore stuff.
Torque it all down with thread lock, the suspension loaded, and lubed or greased and it's going to rattle. That's the tradeoff you get.
