lowering springs
lowering springs
i'm getting ready to drop some cash on some new shocks, probably the bilestein's but anyways, I wanted to know if i needed to upgrade my springs while i'm at it.
the thing is, I like stock ride height and I don't want to lower my car, do they make a stock height spring? all I find Is lowering springs...or do springs not add performance at all? and stock is perfectlly fine....?
thanks...
thanks...
ummmm no, and no. good springs absolutely do improve handling. and if they're designed correctly (i.e. use balanced and proper rates for the amount of drop) they will ride stiffer than stock, not smoother. quality shocks with lowering springs will make it smoother than stock, but that's only because the stock shocks suck.
Some firehawks and SS's do, that's a decent setup for stock. I had those springs/shocks in the rear and found the springs to be too stiff though. When I would hit a bump going around a corner the rear would kind of "hop" to the side. Either too stiff of springs, lack of shock damping, or most likely a combination of the two.
Best bet for stock height is Koni's with stock springs, or if you want a very small drop use the lower perch.
