lca relocates an s60
im about to order a s60 in a few days, i have umi poly/rod lca's should i go with bolt in or weld in? is there any special ones like for 12 bolts an 9 inches?
Hello,
On the S60 both our standard weld in and bolt in brackets will go right on with no issues- Part # 2010 and 2012
Welding is always best to insure safety if you are running high power levels but the bolt on set can always be welded at a later date.
If you have any additional questions please ask and I will be glad to help.
Thank you!
Ryan
Thank you!
Ryan
