UMI k member and spohn lightweight stands?
Got a UMI k member with upper and lower arms, i know the k member has its own motor mounts but will it work with the spohn lightweight bushing stands???
UMI's stands are welded onto the k-member (or at least mine are) so spohns stands won't work. You'd either need a spohn k-member with the motor mount plate to bolt on to, or keep the stock k-member and bolt the light weight stands in. Since you've already got the UMI k-member though, there isn't really a reason to get a spohn k-member and it'd be a pointless waste to bolt the stands on a stock k-member if you are going for total weight savings in general.
