ABS/TCS delete?
ABS/TCS delete?
is SJM still around? Im getting a new rear end and my abs and tcs dont work as it is because of my tire size difference so im just going to save the money and delete everything and was wodnering who sells a good kit to delete everythign
That's about it. If you want to save some money and you have no need for a link lock, buy the Wilwood proportion valve only for $40 and hit up your local car parts store for the proper fittings you will need. Bend the lines yourself and you can easily get away with doing the delete for under $40-$70.
Thanks for the support and reference emulsified. We're still here. Building a kit from scratch, you can do it but it really isn't much of a savings. Especially if you factor in time. The wilwood proportioning valve with tax/shipping will be ~50.00 and basic lines add 20.00. When you remove ABS you completely remove any bias controlling. You NEED a proportioning valve to tune your brake system. No bias controllability and no tuning...You've got about as much luck as hitting the lottery and your system being correct with no ABS or no bias adjustability.
You'll still need fittings, line and time to play around with something that will work for you. The base kit with the proportioning valve, lines every fitting and preformed lines are only 139.99. If you're one of the few that want a custom configured kit, we do offer customers that want everything they need but want to create their own custom formed kit all the parts necessary. This removes the hassle of searching everywhere trying to locate OEM style fittings without adapting to make something work. The cost is still the same for the kit with non-preformend lines. The material components actually increase as though the lines are not formed; we supply additional fittings to meet varied custom needs.
The best method in my opinion is to use the prefabricated kit which places the components away from heat sources for prolonged life ease of installation and adjustment and repeatable results.
Let me know if anyone has any other questions or comments.
