!HELP! woth front UMI swaybar install
Everything suspension wise on my car is UMI, so got there front and rear sway bars, rear went on no problem. The front not so much. I can not tell you how frustrating this is. The bolts UMI supplied are to short, even when not on the car the nut BARELY grabs, on the car its not even close. Ive had the suspension compressed, un-compressed, i tried installing the ends first still wont go. Anyone have this issue? Kinda pissed off and hope maybe im just clearly missing something and not that i got short bolts.
So any ideas before i drive to the damn hardware store to get some longer bolts?
all Energy Suspension and Prothane end links are like this (literally just finished replacing my Prothane links for some shorter Energy links since my car is lowered). The trick is to put a jack under the end link and jack it up a bit to compress the bushings and allow you to grab the thread with the nylon nut. The problem with the factory bolt is I don't think it is the same diameter as the Prothane/Energy ones and will fit loose inside the bushings.
I just ran into the exact same problem, I couldn't get the front end-links on, but then i realized I had a extra bolt set from Strano's bars and it was a good inch longer. Bam install done.
When using longer bolts you have to make sure you have enough thread. When I replaced my 1 7/8" end links for 1 5/8" ones I originally wanted to use the bolts from the old end links but when putting everything together I realized that there is so little thread on these bolts that I would probably run out before I got them tight enough (and they were only 1/4" longer).
Hello
Thanks for choosing UMI Performance for your suspension needs. The hardware that is provided with the kit will fit ( I guarantee it) But it is tight and if you have any questions give me a call and I will be more than glad to explain how you have to do it. Because if I try and type it I am sure I will confuse you. So If you have any other questions feel free to ask. The best advice is do the end links first and once you get them started. Then do the body mount bushings.
Thanks
Brad
Thanks
Brad
I know this is an old thread but this is exactly the problem I'm dealing with.
I'm working on this install now as well and I've got to say I'm genuinely pissed about the situation with the front endlink bolts. This whole business about having to compress the endlinks BEFORE the nut goes on is bullshit. ^^^ Brad, would it have killed you guys at UMI to include bolts with another 1/2 inch of thread? I understand you say it will work and it probably would after quite a bit of "persuasion" on the part of the installer but in the end this is a huge pain in the *** which could be resolved very easily by the addition of longer bolts. I for one do not intend to fight with these parts and break out the jack every time I need to reinstall the swaybar. I'm leaving for the hardware store now to get new bolts and do the job right the first time.
The supplied end links will work, the install is a little tricky with a bar of that size. Take a few minutes and call Jerry here at our shop, he will explain how to install the supplied end links.
Thanks,
Ryan
What I ended up doing was getting a longer bolt, 8 inches long, the UMI supplied one is 7 inches long. The problem with bolts like these is that only the last inch has thread on it and the rest is a smooth shoulder. This creates a problem where you won't be able to torque down and compress the endlinks properly. So I took the bolts to a local machine shop and they added another inch of thread at the shoulder. The bolt above is the new bolt and the one below is the UMI supplied bolt. You can see the new bolt starts its thread at the same place the UMI one does, only difference is the extra inch of thread.
This allowed enough thread to come up out the top of the stack of bushings/sleeve/washers for the nut to grab onto. Below is the new bolt installed and tightened. This cost about $20, bolts and machine shop work combined, so yeah I had to pay but this install and every one which will follow will be much easier and quicker.
I'd like to make a note of something that was not mentioned in the UMI instructions for anyone who has yet to perform this install: When torquing down the endlinks do not torque them to 17 foot pounds as instructed in the factory manual to do with the stock endlinks, instead tighten the endlinks to the point where the bushings compress and become as wide as the washers that hold them in place. I hope this bit of information may come to use for someone.
Glad to hear you got it to work. Just make sure that bolt isn't too long that it hits. Load the suspension and check around the link.
Also for sleeve, Jerry didn't realize that you have an older style front sway bar. Our newer design offers more room under the engine since we changed the bends in that area. The older design cleared fine but we revised it mid last year. The older design was more sensitive to end link length because it could rotate into the balancer, the newer bar doesn't have this issue because of the new bending procedure.
.....What I ended up doing was getting a longer bolt, 8 inches long, the UMI supplied one is 7 inches long. The problem with bolts like these is that only the last inch has thread on it and the rest is a smooth shoulder. This creates a problem where you won't be able to torque down and compress the endlinks properly. So I took the bolts to a local machine shop and they added another inch of thread at the shoulder. The bolt above is the new bolt and the one below is the UMI supplied bolt. You can see the new bolt starts its thread at the same place the UMI one does, only difference is the extra inch of thread.
Observe the pic shown by the OP in the first post at the top of the page. See how the bolt doesn't come all the way through the hole? That was what I had to deal with before switching to the new bolts.
