Package deal, hawk hps + rotors
Old 06-14-2010, 11:19 PM
pHEnomIC's Avatar
Default Package deal, hawk hps + rotors
Any good place to get a good deal on a package of some good pads and brakes for all four corners? I was thinking hawk hps + decent rotors
My pads are shot and it looks like my rotors are considerably worn as well.
I was thinking about getting some decent rotors, doesnt have to be anything too special. Brembo blanks come to mind. Do these have good corrosion resistance? Are they even worth getting or should i just pick something up from autozone?
Old 06-15-2010, 01:59 AM
Mike@ZMS's Avatar
I can set you up with everything you will need.
I have a package put together that covers everything you need and at a very good price.
http://www.zenithmotorsports.com/spo...-and-rear.aspx
If your in Michigan I can most likely get this package to you next day with no extra charge over ground freight.
-Mike
Old 06-15-2010, 09:29 AM
NVR_SPDS's Avatar
Check out Sam Strano's Brake Package 2. Its not the cheapest out there, but after about 2 years, the rotors still look great, and they work!!! http://www.stranoparts.com/partdetai...D=90&ModelID=7
Old 06-15-2010, 01:08 PM
LS1TECH Sponsor
Sam Strano's Avatar
BP2 has ATE rotors which are coated and more of a premium rotor. I also have BP1 which has Hawks and a more economical (but still good quality) uncoated rotor. BP1 is $350, BP2 with the ATE's is $499. http://www.stranoparts.com/partdetai...=191&ModelID=7
There are other kits with brake line/fluid too, and one set with ATE rotors for your guys with C5 front conversions as well (BP5).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Quick Reply: Package deal, hawk hps + rotors
