Prothane Motion Control (Total Kit's) Advice Please !!
Strarting to work under the car any one used the prothane total kit 7-2009
if so can you please provide me the detail's of the kit & what bushing or rubber part's does it cover .... if there is a manual that is provided with the kit !!
Input Appreciated in Advance
Here is a list of components that come in the kit, the parts listed in this kit are a direct replacement parts, any further instructions will be supplied in the kit, if not you can use a factory manual to install them.
**PARTS LIST LIST OF COMPONENT PARTS 1 EA
19-1712 TIE ROD END BOOTS .590"X1.375" 1 KIT
19-409 END LINK SET 4 1/2" MNTG LNGTH 1 SET
7-1129 82-02 CAMARO/FIREBIRD RR S/B 19MM 1 KIT
7-1136 93-02 CAMARO/FIREBIRD FRT S/B 30M 1 EA
7-1201 82-02 CAMARO/FIREBIRD TRACK ARM K 1 KIT
7-1604 TRANS MOUNT 1 OR 2 BOLT STYLE 1 KIT
7-1609 GM F-BODY TORQUE ARM MNT 84-02 1 KIT
7-226 82-02 CAMARO/FIREBIRD RR C-ARM BU 1 KIT
7-227 93-02 CAM/FRB FRT C-ARM W/O SHELL 1 KIT
U-62035 SWY BAR BUSH 21MM ID "B" BRACKET 2 EA
U-62102 93-97 CAMARO FRONT SWAY BAR 32MM 2 EA
