Strange SA struts w/ what springs?
Old 07-11-2010, 07:18 PM
tnmotown's Avatar
Question Strange SA struts w/ what springs?
Well I've been thinking between QA1 12-ways and Strange SA front struts and decided Strange since they are almost the same price. Now I was just curious what springs do I run with them? I want a 300# rate spring and didn't know if the QA1 springs would work with them? Also where would be a good place to order them? Im also thinking about some CE rear drag shocks and ditch the lowering springs. Hope for some better ET's
Thanks in advance....
Old 07-12-2010, 01:49 AM
tnmotown's Avatar
Well after looking at the Strange SA struts more, It calls for a 14"x2.5" coilover spring. So would this QA1 coilover spring from summit work? has the same dimensions it calls for:
http://www.summitracing.com/parts/HAL-14300/
Old 07-12-2010, 02:12 AM
02sleeperz28's Avatar
I run Strange on my car. The 300lb spring is perfect for street/strip. The CE for the rear is a decent shock. Good luck!
Quick Reply: Strange SA struts w/ what springs?
