Aftermarket panhard bar question
Old 07-14-2010, 01:59 AM
davidz's Avatar
Default Aftermarket panhard bar question
Is an aftermarket non adjustable panhard bar supposed to be shorter than the stock panhard bar?
Old 07-14-2010, 02:15 AM
Snake_Skinner's Avatar
I dont really know for sure, but i think im safe to say NO.
Old 07-14-2010, 04:44 AM
mediocrels1's Avatar
all of them are stock length...meant to go on stock ride height cars...
Old 07-14-2010, 07:04 AM
UMI Sales's Avatar
Hello
Like mentioned above a aftermarket stock length pan hard bar will be the same length of a stock pan hard bar when it comes to center/center on the mounting locations. If you have any other questions feel free to ask.
Thanks
Brad
Old 07-14-2010, 08:41 AM
davidz's Avatar
Well I just had just got a spohn one and it wont go it because it about a quarter inch shorter than my stock one. I was woundering if I should be trying to send it back or something
Old 07-14-2010, 08:55 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Is this measurement estimated or accurate? I only ask because it's possible that you got an S197 Mustang panhard rod by accident. They are identical in width and bolt sizes but shorter than an F-body bar.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 07-14-2010, 08:59 AM
davidz's Avatar
its estimated. I put it hole to hole with the stock one after it wouldnt fit and the holes dont line up by about a quarter inch.
Old 07-14-2010, 09:36 AM
BMR Tech2's Avatar
I would definitely contact Spohn about that. 1/4" isn't much and you could easily install it but it's not right. I checked the Mustang PHR length and it's more like 1.5" shorter than the F-body...
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 07-14-2010, 01:54 PM
Travis Johnson's Avatar
Is your rear end centered? If your drivers side sticks out, shorter might be better.
Checking with the manufacturer can't hurt though.
Old 07-14-2010, 02:48 PM
z28bryan's Avatar
I have a question just out of curiosity. I've never measured both to compare. Wouldn't it seem like an aftermarket adjustable PHB should be shorter than stock at shortest setting and longer than stock at the longest setting, so that you can make adjustments either way?
Old 07-14-2010, 04:43 PM
BMR Tech2's Avatar
Yes, that is accurate. We have 2 inches of thread on our adjusters which allows up to 1.25" of total adjustment. Our panhard rod is designed around the OE length so when the adjustment is in the center of the threads, the BMR panhard rod would be OE length. This gives you the ability for 5/8" of adjustment in either direction.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: Aftermarket panhard bar question
