jegster trq arm
jegster trq arm
i just saw that they offer a tunnel mnt trq arm . this is exactley what i needed for my car seein as my dual exh covers the area that i would need for a chassis mnt arm and im tired of the arm from my trans wreckin trans mnts . are these things any good orrrr not so much
http://www.jegs.com/i/Jegster/550/40095/10002/-1
this is what im talkin about
LS1Tech Premium Sponsor
we have a tunnel mounted torque arm setup that uses a crossmember designed specifically for the dual exhaust cars and does not affect ground clearance at all. it is constructed of chromemoly and comes with a driveshaft loop as well. pm or call us for more info and pricing.
From what i read about that Jegster TQarm in question, it is a pain to install and if you do not get the adjustable version, it seems everyone ends up with a 0 pinion angle. Not only that but you must drill the holes in your body (14) to install the bracket
From what I have seen the adjustable jegster arm works! There are 2 local cars that run it (one runs 8's the other 9's) and they hook! From what I have heard, these are not the only cars going this fast with this arm either.
