installing sfc?
Old 07-20-2010, 01:24 PM
calcamLS1's Avatar
Default installing sfc?
looking for the howto install subframe connectors on a drive on lift...i remember seeing one on here i just cant find it...help please, i need to get this done before i go to the track this weekend so thanks
Old 07-20-2010, 01:40 PM
my bandit's Avatar
What brand sfcs do you have?
Old 07-20-2010, 02:03 PM
UMI Sales's Avatar
Hello
When installing the SFC's on a drive on lift. What I would suggest is take the front control arm off of one side (at a time so the rear doesn't shift). Then place the SFC in location and put hardware in place to hold it in place But do not tighten. Then either weld them to the front front or bolt them to the chassis. Seeing how the vehicle is on a lift the chassis is already loaded. Then repeat on the other side. If you would like I will be more than glad to email you a set of instruction so you have a better idea on what needs to be done.
Thanks
Brad
Old 07-20-2010, 02:53 PM
calcamLS1's Avatar
I have the UMI 3 point bolt in....thanks alot!
Old 07-20-2010, 04:34 PM
libertyforall1776's Avatar
It is supposed to be a lift that supports the wheels! Not just a lift.
Old 07-21-2010, 12:31 AM
calcamLS1's Avatar
installed...great fitment car feels alot tighter...i would definitely recommend UMI 3 point sfc's
Old 07-21-2010, 07:30 AM
UMI Sales's Avatar
Hello
Thanks for the great comments! Great to Hear that you are satisfied with quality and performance of our products.
Thanks
Brad
Quick Reply: installing sfc?
