What kind of strut mounts ?
So today I tried to install my strano springs and bilstien shocks and when I break down the original spring and strut. the strut mount was stuck the metal shaft is rusted together to the strut shaft.So after all that I am faced to buy some new strut mounts what kind do you guys recommend?
So today I try to install my strano springs and bilstien shocks and when I break down the original spring and strut. the strut mount was stuck the metal shaft is rusted together to the strut shaft.So after all that I am faced to buy some new strut mounts what kind do you guys recommend?
What happens with the aftermarket ones is the captive nuts in the mount begin to spin or they don't line up well. Just enough problems to warrant buying the factory pieces.
Also, once you get the Torx head bolts out of the drivers side mount in the two forward bolts, I would replace them with a good hex head bolt instead. A grade 10.9 metric (or maybe 12.9) is needed. Don't get the cheap Chinese made bolts that are grade 2. As the OP said, put a dab of grease on the upper shock nuts when reinstalling. It's almost always only the passenger side nuts that get rusted out since the design allowed for water to accumulate in that spot and rust out the nuts.
And once you get the nuts off the shock (I would just cut them off since you are not reusing the shocks) I would try and get the shaft to come out of the mount after soaking in PB Blaster and seeing if that frees it up. The shock shaft is just pushed through the mount and once the nut is off, you might be able to free it up and slide it out. Then at least you can reuse your factory mounts and not buy new ones. I would try and save them if possible. Just get that nut off, Soak it in PB, and then try and pound it out. As long as you don't completely beat the **** out of the mount when you do it, you should be able to reuse the mount once you get the shock shaft to come out.
Good luck.
1 Post
Just do what I did. What did I do you ask??? Well I too had both nuts frozen and rusted beyond recognition to both mounts back when I was installing my stranos and kyb agx shocks last year. I just drilled through the top of the shock shaft and right through the center of the mount. I basically destroyed where the threads are on the shock and where the "nut", if you want to call it that, is. I ended up with two mounts with freshly drilled and cleaned up holes in the middle. Just be sure not to use a drill bit too big where the new nut will not tighten down when you put the new shock through the mount. Just use a drill bit really close to the size of your old shock shaft. Be sure to use plenty of marine grease on the new shock after you tighten it down on the mount, just slap it in there on top of the nut. This worked great for me and it will save you money and headaches. Oh and to keep the drill bit straight I punched a dimple on the top of the shock shaft to kind of give you a starting point. Let me know if you have any questions.
