STRANO springs, Koni 4/4, UMI panhard pics/review
Installed my Koni single adjustable 4/4s all around, Strano lowering spings (1.25" drop), and a UMI cromoly on-car adjustable panhard bar (roto joints). It no longer has that 4x4 stock Camaro look, but does not looked slammed what so ever. It looks how a Camaro should have came form the factory.
The nice shocks make it ride just like it wasnt even lowered. I am pretty shocked at how smooth the car rides. I thought it would be bumpier and more stiff. I currently have the fronts on full soft, and rears 180* from full soft. I think I need to play with the settings to stiffen it up a bit. It looks like the fronts will be tricky to get to without jacking the car up
Next up is Sam's hollow sway bars, and UMI boxed subframes That I will custimize with 3-point bracing.
Looks good. I have everything but the panhard ready to install. Just need to find some time. From what I heard the car will settle a bit. How were the nuts on the shock mounts? Thats the only part I'm dreading.
Yeah and that's a great idea right???
I agree, when this car has the right combo of springs and shocks even lowered, it has a great sports car ride quality to it. Way better than a few stock suspension cars I've driven. Even after a weekend in a Hyundai Elantra on stock suspension, I was glad to get out of it back into the Camaro.
I didn't notice there was two ways to mount the spring perch when I installed mine so I guess that means I'm on the lower perch? I'm real happy, I got the UMI roto joint PHB and LCA's as well and I need to re-torque them since they have started to make some noise, but the instructions said that might be the case so I will do it this weekend.
EDIT: just re-read your first post, once you get Sam's sway bars on there and a good set of SFC's it will feel like a whole new car. The sways made the biggest difference of everything I put on, should have came that way from the factory IMO.
LS1TECH Sponsor
Running the lower perch with lowering springs is not recommended. You'll end up around 2" lower and with very little working travel. You run a greater risk of damaging the Koni's and if too many of you do that, Koni will start to wonder what's up. I did not design the springs to be run on any perch height but the stock one, if you opt to do something else that's your call--but I'd not encourage it.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Oh.... And I'm glad you guys like the parts. Thank you for saying so publicly!
__________________
