Line Lock Questions
Line Lock Questions
So I bought an SJM line lock kit. I'm wondering if I can use it without having to get the wilwood proportioning valve and keep the stock unit or just delete it?
I think before the ltxshootout I can replace the proportioning valve but I wanna see if I can get away with it for now.
1 Post
Just install the line lock into the front only brake line from the master cylinder towards your ABS block. Need either two custom bent and finished brake lines, or to bend your own (involves flaring tool and such). You can do it if you have enough fingers for nose picking. . . (not that we need to know if you pick. . . just saying)
