Disintegrating bushing? (pic)
Old 08-07-2010, 10:00 PM
MJMZ28Cvt's Avatar
Default Disintegrating bushing? (pic)
I'm getting ready for new rims and I was just checking everything out under the car and came across this. The rubber is breaking apart. I'm not exactly sure what is it, but should I be concerned?
Old 08-07-2010, 10:07 PM
HavATampa's Avatar
You should get that replaced. It's the upper ball joint. If it fails, it won't be a good thing. Replace both left and right ball joints and check the lower ball joints and tie rod ends and other bushings on the front end too. How many miles on the car?
Old 08-07-2010, 10:09 PM
SparkyJJO's Avatar
What he said.
If the upper ball joint separates, you're wheel could just flop over. That happened to a friend of mine. Makes for an interesting ride... Good thing for her it happened when starting off from a stoplight making a turn, so it didn't have a chance to do anything bad other than need towing to get new ball joints.
Old 08-07-2010, 10:24 PM
MJMZ28Cvt's Avatar
Wow ok. Where should I get this part from? The car only has 6,000 miles on it. Could it just be from age?
Old 08-07-2010, 10:50 PM
scj
scj's Avatar
that's just the dust boot for the ball joint itself, which is just a rubber cover for the ball joint grease to stay inside, and protect it from dirt and other abrasive like materials from getting into the ball joint.
i would def. get that checked out by a front end specialist, chances are with only 6k miles the dust boot just needs to be replaced.
has the car ever had any front end work done to it? it's impossible to removed the ball joints without destroying the dust boot, that's why i ask.
Old 08-07-2010, 11:04 PM
MJMZ28Cvt's Avatar
That's what I was thinking at first. The shocks and springs were upgraded in '03. The other side looks fine though.
Old 08-09-2010, 08:55 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Somebody just damaged the boot when they swapped the springs and struts. With only 6k miles I'm sure the joint is probably fine but I would put a new boot on it to keep it that way.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Quick Reply: Disintegrating bushing? (pic)
