Moving the steering rack 1.25". Cons?
Old 08-14-2010, 01:48 AM
jasycz28's Avatar
Default Moving the steering rack 1.25". Cons?
Was looking in the turbo section and found this
https://ls1tech.com/forums/forced-in...ok-inside.html
Basicly says:
what I did was easy.....
slide rack over towards driver side aprox: 1.25" and wallah !!! enough clearance for a 4.5" pipe
I will relocate the rack mounting taps over as needed
and if you can see in pics, there a exhaust flanges on heads which will soon to be up & foward mount headers after I fab them up!
steering shaft does not bind and only things needed are:
1. relocate mounting tabs to the right
2. 1.25" shorter tie rod on driver side
3. 1.25" longer tie rod on pass. side
(both available @ your nearest NAPA store)
Do you guys see this causing any problems? Steering wise?
Old 08-16-2010, 09:33 AM
BMR Tech's Avatar
By altering the pivot locations of the rack and the lower A-arms you could be in for bumpsteer issues.
Interesting idea though
Quick Reply: Moving the steering rack 1.25". Cons?
