I give up, whats the trick to this?
Working on replacing my front shocks & I can't get the spindel seperated from the upper controle arm for the life of me. I have spent the last 3 hours trying to get the two parted & it hasn't budged at all. Any tricks? there is no rust in the area what so ever, I have tried with the suspension hanging, supported, little load, lots of load, turned both ways, straight, etc... Sway bar is disconnected & the shock is completely disconnected as well. Also before its mentioned the nut & cotter pin are out lol.
Just take a good sized steel mallet/hammer and give the upper control spindle arm a few good smacks on the outside of the spindle where the joint goes into the control arm. Don't hit the threads or control arm itself, just hit the spindle part and it will jar it loose and separate it. Usually 1 or 2 good smacks will do it. maybe 3 or 4 if you swing like a girl.
trust me on this. I've done a thousand of them this way. And no you won't bend the spindle.
i used a jack to lift the spindle up a bit so it didnt put added stress on the shock. and it popped right off. if the spindle is hanging then its pushin down on the bolt so it makes it harder to get out. jack helps support it a bit.
A pickle fork is not expensive, and definitely takes the work out of this. I haven't used one on the TA as I have not done any suspension work on it, but I have lowered 3 Silverados in the past. The first one I tried all types of ways to get it loose like described above. I finally got the fork and had it loose in 5 minutes. It then became one of my I-rarely-use-this-thing-but-would-beat-down-anyone-who-tried-to-take-it tools.
Thanks guys, I got it out though, I just ran to Autozone & picked up an extra can of man lol. Actually I had been hitting in the wrong place 2 good wacks & it was out.
Never needed one?????
My pickle fork is one of my most used tools, lol. It's in my small tool box of "must haves" that I keep in my Jeep.
Pretty much any job I do on that thing I use the pick fork for something or another. It's a great hammer and prybar, and it works wonders in encouraging a stubborn coil spring to go back into it's home. I've actually even used it to pop balljoints a time or two also.
wrencher
There's even a better set-up to remove suspension components. Specially if your going to reuse them. Sometime pickle forks tear up the grease boots etc.
http://www.sears.com/shc/s/p_10153_1...ype=G7&prdNo=7
