lowering spring
lowering spring
I have a 98 TA I want to lower what are the best springs for the money? What else has to be done when you drop a car? I'm going for looks mainly here thanks
I have Strano's and Koni's. I haven't installed them yet. Now, I will wait til it gets cooler. They give you a 1.25" drop. You will need shocks. Any lowering springs will kill stock shocks in no time. Yes, it has been done but the ride is horrible. You also need an adjustable Panhard Bar to center the rearend. The rear is ususally off center a little. Not real noticable at stock height.
LS1Tech Premium Sponsor
BMR springs have a 1.25" drop for the front and rear. The 1.25" drop has a great look to it, but doesn't cause problems with bottoming-out your car.
The BMR front spring rate is 550 pounds per inch and the rear spring rate is 160 pounds per inch. These rates will give you a streetable, but aggressive ride.
The SP001 BMR springs are priced at $229.95. Compare this price to the price of other springs before you place an order. BMR springs are in stock. We can ship them today if you place your order before 3:30pm EST.
When you lower your car, you change the geometry of the suspension components. You SHOULD replace the control arm relocation brackets and install an adjustable panhard rod if you lower the car.
Save some money and buy a package that has everything you need:
Here's a photo that shows everything :
LSP003 Package Image
Here's a link to our website for more info: CLICK ME
You should replace the struts/shocks also, but if you are primarily going for looks, you may be able to keep your stock struts/shocks.
LS1TECH Sponsor
Strano Springs have been around for a number of years and have never changed design or rates. $275 is the price, but that is shipped to your door and when you compare that price to cheaper springs with shipping the difference is minimal for a long-term, proven product that has caused others to make changes to their products.
SP141 Strano Springs are in stock as I type this. We are, from time to time out of them as they are a big mover.
LCA and LCA brackets, even an adjustable Panhard bar are not necessary. They might be recommended (mostly the adjustable PHB), but in no way are required. In fact my own car, which I've won multiple SCCA National Championships with has GM LCA's and no brackets (and Strano springs). Further, when we did the suspension on a certain magazine car and it and the tires cut some 7 seconds a lap off, that car did not have LCA's or brackets added. There are times and places for those parts, but I do not consider them a requirement. I do sell those items, of course, if we find you have a need for them such as axle hop issues.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
