Need LS1 brakes for LT1. Who sells everything?
I've heard that the LS1 brakes are lighter than the LT1. I'm sure that has to do with the LS1's calipers being aluminum.
But since my right caliper is siezed up I might as well change the brakes. The question is, where do I get the parts? Am I going to have to scoure the junkyards?
What else do I need besides LS1 calipers, rotors, and spindles?
Thanx for you help guys
My mistake. I thought just the rear was aluminum. My car's been off the road for a decade so I forgot a few details here and there. Thanx for the clarification. I thought the LS1 front brake system was lighter and figured I could lose a few more pounds after the K member swap.
if anything, LS1 brakes are heavier. The rotors are 1/2 larger in diameter(more material=weight), the calipers are bigger and have more parts(more material parts=weight. the spindles are pretty much the same weight. just different design for mounting the caliper.
so you wont really be losing any weight. You will have some fantastic braking though. It made a huge difference with my car.
I suggest TrackBrackets
http://www.hawksthirdgenparts.com/br...brackets-.html
They are currently on sale (not at that site) for $120.
You will also need abutment brackets for the pads to ride in.
Unless they're a special alloy that is really heavy and rusts, they're not aluminum. I have a pair sitting in my garage, they weigh 13 lbs each. I didn't weigh the LS1 calipers I put on, but they felt a couple pounds lighter. You're not going to save much weight though.
You can pick up everything you need on ebay fairly often, that's what I did.
I've heard a lot of people need longer brake lines. I picked up a set of C5 lines for free that worked great. I never really measured to see if the original lines would have worked though.
I know this is an older thread but I am doing the conversion right now and was looking for some brake line options when I saw it. I have all the parts here so I weighed all the components (spindle, hub, caliper and caliper bracket for the ls1) in case someone else was looking. The ls1 setup was 49 lbs and the lt1 was 56 lbs. This was on a bathroom scale so I'm sure it's a little off but you can tell the difference in the weight.
UMI sells an adapter bracket for LT to LS/C5 brake upgrade & I've had this brake setup on the car for 3 years and not a single prob. No changing of the spindle or anything else is needed; however you will have to cut off one of the spindles ears that mounts up to the OEM caliper for the adapter to mount....no biggie- the LT brakes suck anyways. Get ahold of them...simple as that
Im running brakes off an 02 ZO6 and no comparison in performance. Call shops that work on Vettes and look for 'fresh-trade-ins' from those that upgraded their Vettes from OEM brakes to something else. (caliper & abuntment bracket) You'd be amazed what deals you may find. Pics of my UMI adapter and pad & rotor change this past weekend before running it at Road America.
I'm running Earls braided brake lines and DOT 5.1 fluid.
OWN3D BY MY PROF!
I have a set in my garage that I've been thinking about swapping over. I want to put the CTSV calipers I have in the garage on my 95, but I have 17s on the front right now. I'd need to swap the wheels onto my Formula, buy two new tires, and the remaining conversion parts. It is on my list of things to do, but I may just end up swapping to the LS1 brakes when I change the rears from drums to disks.
I am doing the exact same thing with my 95. What all did you have to do to swap these over. I have a rear out of a 2000 Camaro with an open carrier and disk brakes. I bought a 2.73 2 series posi that I plan on swapping over so everything is the same. I ended up having to chop through the e brake cables to get them off of the car as I was in a hurry. Will the 95 cables work on the 2000 brakes?
FirehawkJeff on ebay aka http://www.tacreationsusa.com/
I installed his conversion kit for my old '95 to replace the rear drums...
Sic em G
The following users liked this post:
biketopia (07-20-2021)
