About to buy Hawk HPS pads - are there 4 in a set for $70?
About to pull the trigger on HB249Z-575
I have never bought these so I don't know how much they're supposed to cost. I'm thinking 4, but just wanted to clarify before I hit the Submit button.
Also - is it okay to get these just for the front and maybe the cheap Wearever ceramics for the rear?
Thank you and sorry for the stupid questions
Thanks!
Well, I do a LOT more miles than you guys...20K is only a few months for me...and I average a set of pads every year (45-50K).
To be honest...this time I went with the top of the line AutoZone pad lol...performance is pretty dam comparable to the Hawks I was running, and the rotors are a LOT happier.
Last time around 1 set of HPS pads, properly bedded, brought brand new Brembo blanks down below minimum thickness before they (the pads) were even halfway worn, and previously another set of HPS pads had done the same to ATE rotors.
Also...the dust from HPS pads is KILLER...I have to clean my wheels every day anyways (go 150 miles a day and you'll see why), but the dust from other pads is a lot easier to clean off the rotors...especially if say, you drive a few days in the rain and can't clean the wheels until the rain stops...3-4 days of buildup (so 600 or so miles) in the rain is a LOT of brake dust...the HPS dust used to be baked in, and I'd have to clean the wheels with compound to get it off...with the regular pads, I can just use car wash soap...waxing the wheels helped a little, but not as much as switching pads.
Like I said, they're GREAT performers, but if you drive the car a good distance, daily, they're ridiculous on rotors and difficult to clean up after.
I do agree that the pads dust a good bit, but that's to be expected from a more aggressive pad compound. Any performance pad is going to dust more than OEM-style replacements. Can't say that I thought the HPS pads were only a marginal upgrade over stock pads, though - with HPS and Brembo blanks, the car felt much better stopping, both in stop time and pad response, compared to stock pads and rotors (both which still had plenty of life in them).
I'd still recommend HPS or the comparable EBC pads (not sure how their "color" scheme works) and good blank rotors, with the caveat that the user understands that performance pads are going to be dirtier and potentially cause more rotor wear than a set of OEM replacement pads.
LS1TECH Sponsor
Ahhh, are you sure you had HPS and not HP Plus? I, and others, use a ton of HPS's and the wear is pretty much like stock.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Also the part number the OP Put up, those are Hawk Ceramics.
__________________
LS1TECH Sponsor
That's not normal. Could be I suppose--but I've never seen that on any of my cars, or my customer's cars running actual HPS. I only say what I said because I see folks often say things like "HPS Plus" and there is no such thing--but it's what they think they have. If it's a Plus it's not an S.
The car I've been autocrossing the last 3.5 years has HPS all around and is still on it's OEM rotors.
__________________
For what it's worth, I actively rev match down shifts to let the engine slow the car down as often as possible too...150 miles a day, no matter how you drive...takes it's toll on tires and brakes.
