horrible noises
horrible noises
Well just got my car on the road after cam swap. Put everything on at once (adj lca, adj phr, koni 4/3 strano springs, moser 12 bolt) when i hit a bump hard sounds like the wheels are gonna come threw the floor. Also im geting a weird pulse after 12 bolt install. I have a alum stock ds out of a m6 an i have a 4l60e. Are they the same?
Any help would help
Any help would help
Any help would help
Any help would help
I put some roto joint lca and a phr from umi on my stock 01 ss this past spring and there is a lot more road noise than stock, especially when I hit a bump or go over railroa
d tracks.
d tracks.
I put some lca and phr on my stock 01 ss this past spring. The car makes a lot more road noise, especially when I hit a bump or go over train tracks, I can be kinda jarring
Are your LCA's rod ended?
As far as the road noise, I did the same mods as you & I'm going through the same thing. I did sone research on here and everyone suggest to tighten the control arm bolts more, apparently they need to be real tight and are known to loosen up. So I'm going to get back under and do so and add some thread locker.
Okay looking under the car i found a swaybar link on wrong. Fix one noise
I needa fill my lca phr bushings with grease tonight
An what are the chances my over axel exhaust an slaming the body?
What kind of bump stops are they? GM replacement or something else? (are they WS6/SS stops and are you using the metal spacer with them?)
Are your fenders rolled? And did you adjust the panhard bar to center the rear end?
Your exhaust certainly could be hitting the body, or the just the axle, get under there and look for marks.
could be hitting the axel like he said, or like mine...its sitting on the rear cross bar (dont know what the technical name is) and i hear literally every single bump, good exhaust work right there..
