01 ss with zr1's. can i drop my ss???
Old 09-17-2010, 05:56 AM
Ls1Joey's Avatar
Default 01 ss with zr1's. can i drop my ss???
I wanna buy eibach pro kit to drop my ss, but i have zr1's 17 by 9.5 in the front and 17 by 11 in the rear. Will I have any problems with clearance?
Old 09-17-2010, 06:06 AM
egott_91's Avatar
You might have to shave the bumpstops in the rear and do the BFH mod to the inner fenders so the tires don't rub.
Old 09-17-2010, 10:30 AM
Ryanmgaspard's Avatar
Welcome to the forum. "search" you will get that alot. Run 315's... if you run 335's you will have alot more rubbing issues that will not go away.
https://ls1tech.com/forums/wheels-ti...s-rubbing.html
Old 09-21-2010, 11:17 AM
Ls1Joey's Avatar
Thanks helpful information, but what's the BFH wod?
Old 09-21-2010, 12:07 PM
I don't know why people call it a mod. It means big ******* hammer. You will rub the bumpstop at stock height with 315's but when you lower it, you will rub the inner wheel well. So... the bfh mod means once the bumpstop is out the way, do a couple sharp, hard turns in a parking lot, unbolt the wheel and see where it rubs. Then take a 5lb mini sledge hammer and beat the hell out of the inner well until the metal doesn't push in anymore. You will need to do the entire well where it rubs including above and below the rub line. Then spray with rubberized undercoating. In my case I had to cut out the ENTIRE bumpstop and get an adjustable panhard bar so I could move the rear sideways and get even clearance on both sides. I also got adjustable lower control arms and they also helped out with the clearance. You must cut the bumpstop, beat the inner well, and get an adjustable panhard bar at a minimum but after all that I still rub on hard turns with 315 Nitto DR's.
Search:
bfh mod
adjustable phb (do not get poly anything on the suspension, it will bind)
315's
01, 09, ss, zr1
Quick Reply: 01 ss with zr1's. can i drop my ss???
